I have the Fuel pump unplugged and want to know how to multi test the 4 prong leads to the pump... I have a reading on one prong and nothing on the other 3, the one giving me the reading I assume is the one for the fuel gage...I am trying to find the problem and hoping the fuel pump is at fault, cuz I am covered for a replacement at the dealer,. I have pulled and cleaned all fuses just to be sure of and even tho the fuse was good for the fuel pump I replaced it with a new one anyway... I still have no wurr sound from the pump, it did start one and now there is no sound from the pump...
I've looked at a few late model touring schematics and most use y/w wire for power to the fuel level sending unit with a bk/gn ground. The pump is powered by a o/gy or rd/bn wire and it's ground is bk.
On pre 2014 models when the system relay energized it would provide 12v to the fuel pump fuse. if the ECM didn't get a signal from the CKP in 2 seconds it would de-energizer the relay until it saw an input from the CKP, crankshaft position sensor.
