inner tire tube for 180 tyres.
Most inner tubes fit a size range...some say they fit an exact size.
I would have no problem putting a 180/65/16 in your 180/70/16 tire...and they are easy to find.
https://www.jpcycles.com/product/164...saAumuEALw_wcB
I just found out that this tube has centre valve, where as my rim has side valve hole.
Contacted the manufacturer (and few others as well) but they do not make side valve tubes at all.
I'm stuck in a bit of a limbo here at the moment because I've already went ahead and changed the outer rim plus got 180/70 -16 tire.. but can not find the inner tube that will fit the damn setup.
im little desperate now.. haha does anyone run 180 /70 -16 spoked wheel with side valved tube that works for you?
HELP!
