Jetting size
03-13-2018, 09:34 PM
Jetting size
What jets are recommended for a Mikuni 42 mm on a 1998 Harley Davidson Wide Glide with a stock 80cu in. EVO with Patriot Defender 2 into 1 exhaust, torque tubes and open baffle... I like to cruise.. No racing..
03-15-2018, 03:25 PM
Quote:
Originally Posted by
olnegro
Contact Mikuni USA. They will recommend what you should have with your set up.
03-17-2018, 11:43 PM
Jets
I did call Mikuni and they had no suggestion for a starting point on jetting...
03-17-2018, 11:49 PM
03-17-2018, 11:53 PM
Try a #20 pilot, #160 main, and the needle on the 2d step. Tune from there.
03-18-2018, 07:31 AM
jetting
Thanks Plenty I'll do that...
03-18-2018, 09:37 AM
and maybe better responses in the carb section..... I would find out what is stock in there now and go up 2 numbers.....
03-18-2018, 01:49 PM
If legal, you may have to remove the plug to get to the air/fuel mixture screw to fine tune everything after changing jets.
03-18-2018, 03:04 PM
stoneybagger
Carburetor Related
02-22-2017 04:56 PM
misput
03-31-2013 07:05 PM
scaldwellk
05-07-2012 05:54 PM
straydog13
Ironhead
11-04-2008 09:50 AM
Surfit
04-15-2008 03:01 PM
