cleaning oil off concrete floor
I did some researching and found Brake cleaner and some speedy dry works for oil stains...and it does. I used it and it got alot up. The stain on the left was far worse than the the big stainbrfore I started.. The large stain was pretty good but I killed the can of brake cleaner and in my infinite wisdom used a full can of engine degreaser for a second cleanup. It made the stain a thousand times worse. Its now a giant black stain worse than it was before I even started.
Any idea how to get this up?
I dont want the oil and chemicals on the tires
Kingglide549 (07-24-2018)
Received 20,191 Likes
Would a pressure washer work after you`ve done all of that?
I actually watched a youtube video of a guy using a torch on his oil stained paver patio...it worked good. I have a roofers torch that could put down some hellfire but I'm a tad concerned about a fire in the garage as degreaser is a petroleum based product. Although the speedy dry got up all the liquid and I'm just left with a stain.
Step 2: go to Home Depot and buy several canisters of propane
