What to expect with a flat?
"Flats" are not much of a problem...you can feel the change in handling... and pull over to see what is wrong...flats are usually caused by small road hazards like a nail.
"Blowouts" are a problem...90% of the time they are caused by riding at highway speeds...with an under inflated tire...checking tire pressure every time you ride will help a lot...
If you are really paranoid buy a tire monitoring system.
Blowouts on the back suck...but you can usually make it to the side of the road...to change your shorts.
Blowouts on the front really really suck...and will depend on your riding skill, and some luck on if you stay upright.
Do everything possible not to have a blowout.
Received 14,465 Likes
Best thing to do is just keep your cool. Gently pump the brakes, and guide the bike to a safe stopping place. Don't try to force the bike to go straight, it won't, you have have to kind of let it do it's thing while guiding it to where you want to stop.
I've had plenty of flat tires front and rear on dirt bikes, and they behave kind of sort of similar to a street bike. Generally though, you don't have the added hazard of all the idiots on the road around you.
stixvrad (08-07-2018)
I cant say ive had that happen, what did happen though was when i was 18 i tied my hoodie around my waist and took off on my honda 750. Going about 50 mph it came untied and went straight into the rear wheel. The rear tire fully locked up and i was fish tailing it wildly from one side to the other until i came to a complete stop barely keeping it upright the whole time. Since then i have been completely paranoid about loose things or strings or anything loose on the bike getting stuck in the rear wheel and am over cautious about it.
Never had a blow out, but I've had 2 punctures one in each, back was the worst, I was doing around 45 and the bike started weaving all over the road managed to slow down and stop without coming off. Front tyre went doing about 30 mph, only knew about it when I slowed down to make a tight turn and the steering became really heavy, thought it was a problem with the steering at first till I saw the flat tyre.
