help
Old Oct 24, 2018 | 04:50 PM
Rich Ventarola's Avatar
Rich Ventarola
1st Gear
Default help
have 13 electra glide acc fuse keeps blowing ten miles or 500 miles when it blow only my brake light blows running stays on turns stay on they are all supposed to all be hot from 0/w wire so y do they lose power !!!
Old Oct 24, 2018 | 04:54 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Say whaaaat?
Old Oct 24, 2018 | 05:27 PM
Rich Ventarola
1st Gear
Default power problem
i have a 2013 electra glide acc fuse keeps blowing and i only lose my brake light my running light stays on my turn lights stay on and work all those are power from orange and white wire so how come only my brake light wont work thanks
Old Oct 24, 2018 | 06:47 PM
DanHappy's Avatar
DanHappy
Originally Posted by NORTY FLATZ
Say whaaaat?
Bunch of periods missing...
Old Oct 24, 2018 | 07:09 PM
cdestuck's Avatar
cdestuck
Yea, make a couple real sentences and fuses will quit blowing.
Old Oct 24, 2018 | 07:14 PM
nobodyknowsme's Avatar
nobodyknowsme
OP, that would be the person that started this thread. Take it east and type slowly, so that us old farts can understand. And please use proper punctuation as it is easier for those of us that grew up some decades ago. We really would like to help you. Best of luck and stick around as we all learn things here. Also grow thick skin as some of us can be ornery and contrary when the mood strikes, or if we just had a bad day, maybe the ED ran out or any one of a thousand reasons....
Old Oct 24, 2018 | 08:06 PM
Gearhead88's Avatar
Gearhead88
What were the events leading up to the blown fuse(s) ?
Handlebar change ?
Grip install ?
Lowering kit ?
Heated grip install ?
Paint swap/install ?
Check tail light wiring harness under the rear fender for rubbing
Check handlebar wiring for pinched wires
Check brake light wiring for pinched or rubbed wires , look at rear brake light switch
Old Oct 25, 2018 | 04:58 AM
monkeyboy22's Avatar
monkeyboy22
Yesterday, 06:35 PM
Rich Ventarola
New MemberThread Starter
Join Date: Oct 2018Location: CHARLOTTEPosts: 3Thanks: 0Thanked 0 Times in 0 Posts
blown fuse and help
i have a 2013 electra glide. acc fuse keeps blowing and i only lose my brake light. my running light stays on, my turn lights stay on and work. all those are power from orange and white wire so how come only my brake light wont work? thanks
This is quoted from another post he made abut his problem (I added punctuation to make it easier to read). I'm no electrical wizard so I'll let those in attendance tackle it.
Old Oct 25, 2018 | 07:39 AM
rparnel1's Avatar
rparnel1
I had an '07 ultra. Plugged in something to the cigarette lighter that blew the AC fuse and also lost my brake light. Would have thought those would be on separate circuits, If you are blowing fuses, then you have a short to ground somewhere. those can be a bitch to find!
Old Oct 25, 2018 | 07:44 AM
TwiZted Biker's Avatar
TwiZted Biker
Simple you have a wire intermittently grounding out, start looking and check all your grounds.
