I am so sick of cheap junk
Putting air in your bike's tires is one of the easiest maintenance jobs you can do. Right? Yes, it is SUPPOSED to be.
Providing you can find a gauge that WORKS. I have three difference gauges and they are all giving me different readings.
I bought two brand new valve extenders that are supposed to make the job REALLY easy. Both of them just broke.
I am so tired of buying cheap junk from third-rate shysters.
Thanks for letting me vent. I'm trying to get off nicotine.
The following 5 users liked this post by tmac00333:
bigal51 (01-04-2019),
crazytown (01-02-2019),
Harfar (01-02-2019),
LIMike (01-03-2019),
Northernproducer (01-11-2019)
tmac00333 (01-02-2019)
Received 4,616 Likes
I don't think there's a one gauge fits all. Near right angle end stick gage for those hard to reach wheels, long shank to reach others, a dial gage when you have plenty of room, and my favorite, a digital readout, are my minimum set. Also have a cheap ball end I removed the stem from and drilled out as wide as I dared to get maximum airflow for seating tubeless tires on rims when I install new tires. When it gets down to freezing, my digital quits in a couple minutes, though. Sometimes the old basics work best. I occasionally check my gages against each other, and so far they're all right on. My stick gage is at least 40 years old, too; that's the kind I'd expect the less accuracy with, but it's held just fine.
The sad reality of pressure gauges is that they ALL have a horribly loose accuracy range. That is until you get into precision instrumentation that costs more money than us mere mortals can afford.
Best advice.... take an average of the three, then use that to figure out the correction for what the best/easiest one. For example, as long as you know favorite gauge reading 40psi is "PROBABLY" 37psi....that's all you need to do.
Received 14,658 Likes
Received 17,598 Likes
The following 2 users liked this post by Super Glidester:
Iron lHorse (01-02-2019),
tar_snake (01-02-2019)
The following 2 users liked this post by Jackie Paper:
Mike Lawless (01-02-2019),
