Juts use zip ties to hold it in....no, but really, get the wiring schematic and figure it out. Power, ground, constant power, left front. right front, left rear, right rear speakers(both+ and-) thats about what wires you would be tracing, ignition etc. You will have a hell of a time if you arent electronics savy, and you may even have drivability problems if you tap intothewrong wirezzz...
i haven't really looked into the wiring schematics, but the newer bikes have can-bus systems, whereas the older ones don't. that may cause some problems since with canbus you have fewer wires carrying the signal back and forth.
