turned my ignition on and the abs light lit up.....started it up and the abs light is flashing;;;;the bike has 14,000 miles on it... i checked the trouble codes and it listed none; is there way to reset this light?
It flashes until the bike starts moving. Does it flash while it's moving?
no, I have had it for 3 years....this is the first time it has happened.
Maybe the first time you noticed it at around 3 or 5 mph it should go out. If it’s on steady you have a problem. You should also change your brake fluid also.
