abs light
Old Aug 28, 2009 | 04:22 PM
batman10's Avatar
batman10
Stage I
Default abs light
should my abs light be on all the time. It's a 2010 street glide with 400 miles on it.
Last edited by batman10; Aug 28, 2009 at 04:25 PM. Reason: left out year and mileage
Old Aug 28, 2009 | 04:27 PM
DamnYankee's Avatar
DamnYankee
Nope, sometimes it should blink when your sitting still, but once you're over 3mph it should go out.......... see a dealer
Old Aug 28, 2009 | 05:28 PM
eriesportster's Avatar
eriesportster
1st Gear
I just watched the ABS video after getting my new bike. I believe it mentioned that if the ABS light stays on, the unit has detected a problem. Go see your dealer.
Old Aug 28, 2009 | 05:35 PM
46knuck's Avatar
46knuck
If the light is on then the abs part of the brake system is not working. The computer has detected a problem with something. The brakes will now work as a typical bike with no abs. The bike is just like a car, when you start it up the computer checks everything electrical and all lights should go out if no faults are found.
Old Aug 29, 2009 | 06:29 AM
okieblue62's Avatar
okieblue62
Mine was doing the same thing.Turned out to be a pinched wire under the gas tank going to the front brake. Fixed free of charge under warranty.
Old May 18, 2010 | 08:25 AM
hockeygramps's Avatar
hockeygramps
Stage III
Default ABS Brake Light
My 2010 Ultra Classic is in the shop right now for that problem. On my bike, the problem only occurs on cold morning rides. I have never noticed the problem in the afternoon when the temperatures gets above 55 or so ( I live in Michigan). This is the second time in a week I have taken the bike in for this problem. The first time I took the bike in, the dealer just cleared the codes. I love thought of having ABS, but I don't want to have to look to see if the light is on to know if I have ABS or not.
Old May 18, 2010 | 08:33 AM
harley_badboy's Avatar
harley_badboy
Yep, sounds like a problem that should checked.
b2000s81
2014-2024 Touring Models
Sep 28, 2018 06:58 AM
baldguy13
May 13, 2014 09:38 AM
glide2005
Jan 17, 2011 11:56 AM
DocDyna
Dec 2, 2009 07:59 AM
05 FLHTPI
Feb 14, 2006 10:45 PM
