front turn sig relocation
03-17-2009, 11:30 AM
why do the instructions tell you to remove the tank? I can't see why. 08 dyna fxdc
03-17-2009, 02:09 PM
My brother and I just did this on his 08 FXDC, we just undid the fuel quick disconnect, removed the front and rear tank bolts and raised the tank up to get at the turn signal plugs inside the frame. I had to take the plug pins out then re-assemble the plug after relocation. So you don't actually remove the tank just raise it up enough.
Mike
03-17-2009, 02:43 PM
Watch your rocker tops if you do end up just sliding the tank back, the tabs at the bottom front of the tank will scratch the crap out of them.
03-17-2009, 02:48 PM
Sounds like you're speaking from experience. You wouldn't happen to have some scratched rocker tips, would you?
Quote:
Originally Posted by
AK47
03-17-2009, 02:51 PM
max56
lol, they make nice soap dishes so im not too upset. lol.
03-18-2009, 08:31 AM
thanks
I did the job last night, thankyou for some good advice.
03-18-2009, 09:47 AM
AK47
OR ash trays on the work bench.
03-18-2009, 09:59 AM
I took my tank off so I wouldn't mess anything up. It wasn't that bad just made sure the tank was empty.
03-18-2009, 10:36 AM
I took my tank off to have more room to find the connector in the frame. Now that I know where it is I could probably get by just by sliding it back some.
Removing the tank makes a REAL mess if you don't drain it first!
mac5725
01-31-2013 09:53 AM
craigffb
12-23-2011 03:19 AM
Clinton350
01-08-2009 06:37 PM
airvette
09-18-2008 06:58 PM
dg7080
02-10-2008 05:37 PM
