I need help!!!
Old 02-28-2010, 03:26 PM
chris_nelson123's Avatar
chris_nelson123
chris_nelson123 is offline
Default I need help!!!
I need some advice on the best way to get melted plastic off of my chrome pipes. Please all suggestions welcome.
Old 02-28-2010, 04:14 PM
piasspj's Avatar
piasspj
piasspj is offline
When the pipes are hot wipe off as much as you can. Then let them cool down.
Spray easy off oven cleaner on cold pipes (and nowhere else) then heat them up by running the bike. Wipe them off.
Other options you will hear 0000 steel wool and WD-40, (or chrome polish). Don't press hard, it can scratch the pipes.
Use a penny to scrape them off, it has to be an old real copper penny.
They all work, I usually end up using nevr-dull or chrome polish to really get them clean.
Old 02-28-2010, 04:30 PM
TXWARLOCK's Avatar
TXWARLOCK
TXWARLOCK is offline
EZ Off worked for me also.
I sprayed it in a cup first and applied with cotton q-tips.
Do not spray on your pipes as it will eat your paint too if you miss.
Old 02-28-2010, 06:34 PM
carlgrover's Avatar
carlgrover
carlgrover is offline
Received 2,218 Likes on 1,284 Posts
Spray the Easy off onto a rag, then wipe it on the pipes. DON"T spray it in the direction of the bike or we will be helping you decide what new color you want to paint it next.
Old 02-28-2010, 06:58 PM
oct1949's Avatar
oct1949
oct1949 is offline
never dull here, worked on small boot burn..seems like oven remover is the leader...as stated, don't get it on the paint.
Old 02-28-2010, 07:42 PM
golfblues's Avatar
golfblues
golfblues is online now
Received 1,463 Likes on 895 Posts
Easy off cold oven formula over night on cold pipes. Again be careful of painted parts.
Old 02-28-2010, 07:50 PM
rickb's Avatar
rickb
rickb is offline
I use turtle wax chrome polish takes some rubbing but it does the job.
Old 02-28-2010, 08:55 PM
jrspada4's Avatar
jrspada4
jrspada4 is offline
Mr. Clean Magic Eraser and cold water on hot pipes worked for my boot scuffs. Just have to polish the water spots off when they cool.
Old 02-28-2010, 09:04 PM
Sniper318's Avatar
Sniper318
Sniper318 is offline
I used WD40 and a brillo pad...wiped right off and polished the chrome...no scratch or anyting. Was very happy with the results
Old 02-28-2010, 11:34 PM
oct1949's Avatar
oct1949
oct1949 is offline
after rereading Ur post,, U said,,, ALL
http://www.youtube.com/watch?v=A7PwDw1pQtc
Quick Reply: I need help!!!
