How hot does your oil run???
#41
I'm going to argue this point people keep making.
1.) If the oil cooler is keeping your oil temps down, say 10 degrees or more, that is 10 degrees more headroom you have before overheat when you hit a jam.
2.) Every time in the traffic you move a bit, it's just that much more finned or block surface that loses some heat, giving you more time.
3.) Once you begin moving again, it helps get things back to normal sooner, so the engine spends less time under less pressure and overheated additives.
So YES, an oil cooler DOES help in traffic jams.
10-20* is not really a difference maker. On my 103 engines one with and one without an oil cooler the maximum difference in the two was 13*. Fossil oil can easily tolerate 300*. Any full syn is good to over 400*. Try a Wards fan if you are truly concerned with engine wear. My oil cooler does nothing in traffic jams. At idle the engine pumps very little oil for the cooler to cool. Very little volume for very little oil to cool and about no air as well. An oil cooler will solve a problem that really isn't there.
#42
Tell me about it, I'd like to get the Oil Bud but damn, $600. I'm considering the FCS at $275 now.
#43
After our 'MONSOON' summer this year, I've done so little riding, I haven't even put it on, despite switching back to dino oil. FINALLY, the daily rains are backing off, but the weather is getting moderate now anyway.
