How hot does your oil run???
Old Apr 7, 2010 | 07:52 PM
magnum629c's Avatar
magnum629c
Default How hot does your oil run???
This bikes new to me so I dont no ..It got up to 86 today and the bike ran around 205 it went up to 220 for a few mins and then back down to 205. I run amsoil oil... is this to hot ? Im hoping my bikes not running lean I dont think so the plugs look to be ok........so whats ur 88 run at??? thanks
Old Apr 7, 2010 | 07:56 PM
Quadancer's Avatar
Quadancer
I hope ta heck MINE is running that cool! 250 for dino and 300 for syn as limits where additives begin to break down, according to the "labcoats" in here.
I put a couple fingertips on the tank: 3 second hold is about full heat on a summer day. If it scalds me, it's too hot, but I'm a carpenter and things, so my hands are on the tough side. My idle oil goes from a normal 8-10 lbs. to 0 lbs. at overheat, but it can go down to 0 and not really be overheated; it's just a warning to keep moving as I see it.
I found out in a traffic jam when it overheated. With Amsoil.
Old Apr 7, 2010 | 08:02 PM
WWECOUGAR's Avatar
WWECOUGAR
Mine is usually up around 200 on warm days. Might go up some intraffic. I don't look at the gauge too much. Ain't much I'm gonna be able to do about it anyway. It's the main reason alot of guys use synthetic in their Harleys.
Old Apr 7, 2010 | 08:30 PM
spiker's Avatar
spiker
02 Electra Glide Classic carbed,09 Road King Classic PCV,both have oil coolers and Amsoil is used,the 09 runs on the average 25 degree's warmer.On a 80 degree day,185 on EGC and 210 on the RK.
Old Apr 7, 2010 | 08:35 PM
Harleyrider_49's Avatar
Harleyrider_49
Depends......anywhere from 200-230....gotta be be really hot out,an' sit'n in a lot o' traffic (stop/go) ta get ta 230............it'll let ya know when it gets too hot.....it'll just "quit"
Old Apr 7, 2010 | 08:39 PM
magnum629c's Avatar
magnum629c
so sounds like 205 is ok then
Old Apr 7, 2010 | 09:06 PM
Bluehighways's Avatar
Bluehighways
I have a HD Oil Cooler on my TC96 and it runs about 180-230 F depending on the temperature of the day and what kind of traffic I'm in. Everything's pretty much OK unless you see 255F+ as thats when the half life of the high pressure additives like MoSo4 start breaking down pretty quickly. That's not a function of Dino or Syn Oils . . . it's a function of the additive package. Dino oils may leave deposits at higher temps that aren't real good for the bike, but the real problem is what high temps do to the high pressure additive packages.
Old Apr 7, 2010 | 09:39 PM
Dixie Dreg's Avatar
Dixie Dreg
My Fatboy sticks at 200 but if it is really hot outside and I run 80 for a long time it will hit 220. Amsoil dropped my operating temps .
Old Apr 7, 2010 | 10:19 PM
harleydavis's Avatar
harleydavis
With synthetic (Mobil 1 15W50) I am in the low 200's on a cool day and in the 220 range on days over 90 degrees.
Old Apr 7, 2010 | 10:25 PM
magnum629c's Avatar
magnum629c
ok thanks
