Speedometer and tach not working
Hey Guys. New to the forum, and looks like a great group. I just brought home from the dealer the new to me 06 Street Glide a few days ago. I go to take off today and the speedometer, tach, and trip A and B are not working. When I turn on the ignition the left and right blinkers flash (looks like 6 times).
I pulled side cover off and a fuse was blown (I think it was the accessory one). Soon as I turn it back on it blows it again.
Any suggestions?
Any suggestions?
I would think so too. Congrats on the new to you Street Glide! Ck your batt terminals and engine ground to ensure they're clean and tight.
I will check connections but as I look everything over I have no turn signals, horn, tach or speedo. Gotta be something simple. I assume the battery is under the seat?
If you just bought it from a dealer a few days ago I'd go back to the dealer and have them fix it.
I went thru this just after taking off my front fairing to install a hidden antenna. Kept blowing the acc fuse. Must have had a wire pinched somewhere when I put it back together.
So I took off the fairing off again, massaged and moved all the wiring around inside my fairing, put it back together, and have not had the problem since. I never did find the problem but its gone now.
