Re-maping
Old Aug 30, 2010 | 01:01 PM
mooseheart's Avatar
mooseheart
6th Gear
Default Re-maping
I ride a 2010 Tri glide. I have changed the mufflers and the headpipes no more cat's, air cleaner and re mapped. question is the re-map was done with the cat's still installed. Should I re-map again without the cat's and will I see a big diffrence.
Thanks
Old Aug 31, 2010 | 03:52 AM
Watch Guy's Avatar
Watch Guy
Default I can only relate my experience
with my 09 FLHRC. I just installed the V&H Power Duals. (from stock cat equipped pipe) Bike already had a stage 1 and a PCV map. Removing the cat has made almost no perceptible difference. The bike is a little louder but is runner much cooler and a lot faster without changing the map. Depending on your map, you probably won't need another dyno or map but it all depends on the map currently in your bike.
Kevin Dearing
2014-2024 Touring Models
May 8, 2018 07:43 PM
jwm9289
16
Apr 23, 2016 09:52 AM
bayboy75
Apr 2, 2014 10:46 AM
hdnik
Mar 17, 2012 01:49 AM
SGJake
Sep 30, 2010 05:02 PM
