Injector Problem?
Old 01-02-2011, 09:27 PM
Larry the Landlord's Avatar
Larry the Landlord
Larry the Landlord is offline
Default Injector Problem?
I think my injectors may be leaking. When I bought the King prev owner said to turn key and wait for test light to go out before hitting starter. Worked fine, after a while I notice it is getting hard starting doing this warm, so I hit starter right after turning key on. All good. Now it acts flooded if I wait to hit starter when cold. Now the fuel mileage has dropped noticeably. Are the injectors serviceable? need replaced? PS bike has almost 50,000 miles.
Old 01-02-2011, 09:40 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
First check the wires and connections to the injectors as some come loose and cause intermittent problems. I would try running some techron in your gas (3-4 oz per tank) and see if it cleans them. If you do need to replace them get the part number and oreder them from Zanotti's. They aren't that expensive.
Old 01-02-2011, 09:54 PM
geezer glide 56's Avatar
geezer glide 56
geezer glide 56 is offline
could be several things...What model year model king do you have?...Have the cam tensioners been checked?
Old 01-02-2011, 11:02 PM
oct1949's Avatar
oct1949
oct1949 is offline
Yeppers for flooding on starting,,, along with the cam tensioners I'd check the tail light oil level......
Old 01-03-2011, 05:08 AM
geezer glide 56
Might not be firing due to debris on cam position sensor or timing being off due to tensonioners worn down...Laugh if you will but I have seen it...I have had customers tell that their bike was flooding when it wasn,t even getting any gas...He has 50,000 on that bike if the tensoniers have not been replaced...flooding will be the least 0f his problems.
Old 01-03-2011, 09:53 AM
Larry the Landlord
Its an 02. Cam tensioners were replaced at 25,000 miles when the top end was done (by prev owner). Thanks for the help, I will try the techron.
Old 01-03-2011, 11:49 AM
Bluehighways's Avatar
Bluehighways
Bluehighways is offline
If the injectors are plugging, you will NOT have a "Flooding Problem" the issue will be too Lean; and you'll have a Hard Starting Cold and a Hesitation on Acceleration complaint. Running a few tanks of Name Plate ie Chevron, Mobil, 76, Shell, etc. (Not Discount) premium fuel will clean them just as well as any additives. If you've been running Name Plate Fuel, the odds of your injectors being plugged are Slim and None and Slim's walking out the door.
If the Injectors are Leaking that is easy to check. Pull the injectors and arrange them so that they are still attached to the wiring harness and the fuel line. Place a couple of small cans to catch any fuel and crank the engine while you watch the spray pattern and the tips of the Injectors. The Injectors should: 1.) Produce a nice cone shaped spray pattern, and 2.) Should NOT drip even one drop from the Injector after you stop cranking the engine. Even one drop means they are leaking. If either or both Injectors are leaking you will almost always need to replace them. Most chemical cures are temporary at best and are so harsh (very high Methanol content) that they cause more problems in the long run than they solve.
Old 01-03-2011, 12:17 PM
Larry the Landlord
I buy most of my gas from QT, a local conv store chain that sells top tier gas. It is very good gas, rarely need to change fuel filters. Good call on the additive. I will check the connectors and pull the injectors and check them. Thanks everyone for your help.
Mopower
Milwaukee Eight (M8)
02-09-2019 08:47 PM
Glydeman
12-14-2015 07:35 PM
roundman327
06-14-2012 10:46 PM
normyt
05-04-2012 11:11 AM
UltraClassic_2007
05-19-2011 01:28 PM
Quick Reply: Injector Problem?
