Odometer wrong?
Old Mar 20, 2011 | 02:13 PM
coachchris's Avatar
coachchris
Default Odometer wrong?
Hey guys
My and my brother went on a ride last weekend, me on my wide glide, him on his soft tail. All in all it was about 650 miles. Well on his, my trip read closer to 630. Is it common to have a difference in readings? How does the odometer work? More curious than anything else.
Old Mar 20, 2011 | 02:18 PM
chamokie's Avatar
chamokie
The speedometer works off a sensor in the trans. Should not be that far off. Find a measured mile, set the trip to "0", then ride the mile. Should be right on. Or if you have a gps you can do the same thing.
Old Mar 20, 2011 | 02:55 PM
DannyZ71's Avatar
DannyZ71
Did either of you change wheel sizes from OE?
Old Mar 20, 2011 | 05:54 PM
rdam's Avatar
rdam
That's just a touch over 3% difference. My EGC and my wife's XL are usually off a couple miles over a hundred or so.
Old Mar 20, 2011 | 06:10 PM
Thundermug's Avatar
Thundermug
sounds like the difference between a new tire and a tire that almost needs replacing.
Old Mar 20, 2011 | 07:56 PM
Rustell's Avatar
Rustell
I had a short ride today....
GPS says 69.8 miles...odometer says 71.8..
Harley odometers run about 2 - 3% fast..
jimmy z
Apr 6, 2019 02:42 PM
BuckeyeUltra
Apr 12, 2014 09:51 AM
rh8234
Aug 29, 2011 11:11 PM
deadhawg
May 10, 2011 03:34 PM
mississippiboy
Jan 16, 2010 04:43 PM
