Detachable Windshield Questions
Old 09-29-2011, 09:14 AM
kevjo's Avatar
kevjo
kevjo is offline
Default Detachable Windshield Questions
Last March I bought a detach. windshield to use for the winter. Never had one before. Do they deflect any wind from the hands or just the chest area? Any ideas on what i can put under the clips to keep from marring the fork tubes. They have a little bit of rubber on the clips, but when i gave it a trial fitting i noticed little places on the fork tubes when i took it off. Thanks for any input.
Old 09-29-2011, 09:59 AM
Foodog's Avatar
Foodog
Foodog is offline
Your hands will be in the wind and they will get cold.
Old 09-29-2011, 10:28 AM
Ganooch's Avatar
Ganooch
Ganooch is offline
Different types of windshields provide different amounts of wind protection. The best thing to do is see if the dealer will let you try the one out that you want. As for marring the forks, not sure what the solution is. My windshield is a Memphis Shades, so the mounts are different.
Old 09-29-2011, 01:59 PM
bigdaddy33's Avatar
bigdaddy33
bigdaddy33 is offline
Shield will help a lot with face and chest, but not your hands. I have a HD quick detachable with the C clamps and haven't noticed any marring on the fork tubes.
Old 09-29-2011, 02:07 PM
hoethree's Avatar
hoethree
hoethree is offline
Detachable windshields from Harley made for Harley bikes are a bit tricky to put on and take off. You just have to be careful to get them on the rubber grommets without banging your forks, headlamps, etc. Once you get the hang of it, they go on pretty quickly and remove easily. Just be careful. Not sure if this is what you are referring to when you say you have "little places on the forks". Once the shield is securely in the mounting grommet nothing should be touching the forks anywhere. Proper alignment is key! And as has been said, your hands will not be protected at all.
Old 09-29-2011, 03:17 PM
SoALposer's Avatar
SoALposer
SoALposer is offline
For your hands, check your local biker/leather shop and they may have covers that go on the handle bars that you put your hands in, some are long enough to come up almost to your elbows. It coves all the levers and switches. This might help, especially if you have gloves on.
Old 09-29-2011, 06:49 PM
Jonesee's Avatar
Jonesee
Jonesee is offline
A wrap of electrical tape around the fork will prevent a mark.
Old 09-30-2011, 02:42 PM
bkelly1956's Avatar
bkelly1956
bkelly1956 is offline
+1...should be on rubber grommets with nothing touching the forks
Old 09-30-2011, 02:55 PM
oct1949's Avatar
oct1949
oct1949 is offline
For me I think they help a little with the wind, mostly they help keep bugs, sand and rocks or hard things for hitting U in the chest and face.
Most HD shields will give U wind buffering which doesn't bother me, but if U ride with a lid make sure It fits really "SNUG" or it will shake U head pretty good.
I do ride almost 100%with it on, Wife won't ride without it.
Old 09-30-2011, 03:03 PM
Ganooch's Avatar
Ganooch
Ganooch is offline
...Not sure if this is what you are referring to when you say you have "little places on the forks"....
I think that he is referring to the clamps that attach to the forks that the windshield then attaches to. He is saying that clamping those to the forks may be causing the finish of the forks to be marred.
OP correct me if I am wrong...
Quick Reply: Detachable Windshield Questions
