Wheel Bearing Reducer?
Old 11-09-2011, 05:59 PM
MNPGRider's Avatar
MNPGRider
MNPGRider is offline
Default Wheel Bearing Reducer?
Anyone here ever hear of such a thing?
Why not just replace the wheel bearings? Or is a quarter inch more than you can make up with using bearings?
http://www.bkrider.com/bkrider/SKUSe...eria=C01001516
Old 11-09-2011, 06:35 PM
xwhyz1959's Avatar
xwhyz1959
xwhyz1959 is online now
Received 1,489 Likes on 469 Posts
Might be so you can run different year wheels on a bike. I'm sure they press into the inner race of the bearing.
Old 11-09-2011, 06:58 PM
MNPGRider's Avatar
MNPGRider
Just as you can replace a bearing? How can you know what is turning....the bearing, or the spacer against the bearing?
Old 11-09-2011, 09:15 PM
BrianG's Avatar
BrianG
BrianG is offline
or bearing against the axle....
Old 11-10-2011, 05:26 AM
xwhyz1959's Avatar
xwhyz1959
If you don't have your axle nut torqued to spec, your wheel bearing may be turning on the axle. Have you ever had to press your axle through a wheel to install it?? That's what the spacers are for, to pinch down on the inner race and and keep it from moving while the bearings and outer race do move.
Old 11-10-2011, 06:51 PM
tallboy56's Avatar
tallboy56
tallboy56 is offline
You don't want to " pinch down" on the inner rings...that causes preload and ultimately, premature failure. The spacers should prevent that from happening. If the axle nut causes the inner rings to be pushed inward while the outer ring is held in the hub, that's trouble waiting to happen.
Last edited by tallboy56; 11-11-2011 at 04:46 PM. Reason: misunderstood the writer's comment
Old 11-10-2011, 06:56 PM
SportsterBob's Avatar
SportsterBob
SportsterBob is offline
Wheel Bearing Reducer must be something new....Never heard of it!
Old 11-10-2011, 07:13 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,608 Likes on 3,851 Posts
Some wheels like mine have 3/4 axle. Guess you put these in a larger 1" ID bearing and run them on 3/4 axles. Need to be real careful. Some axles are actually 25mm or 0.984 My opinion is doing this kind of adapting is dangerious.
Old 11-10-2011, 08:21 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is online now
Received 48,102 Likes on 17,547 Posts
Yes they have the reducers J&P and Vtwin sell them , you can also change the bearings but you also need to replace the inner spacer spacer too and that can be a bit involved with aftermarket wheels or bearings sometimes . On occasion things can be off a few thou of an inch dimension wise you need to check it all for proper fit .
Old 11-11-2011, 05:33 AM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 18,531 Likes on 5,470 Posts
This is the way to go when swapping wheels. Changing the bearings will require a trip to the machine shop for the inner spacer...this eliminates that step and they sell them for 25mm too.
Quick Reply: Wheel Bearing Reducer?
