DO YOU NEED THE HEAVIER CLUTCH SPRING?
If you run a 95 or 98 kit in your bike are the heavier clutch springs really necessary?I spoke to a few experienced builders and they say not needed unless you ride 2up alot. What are your thoughts
If your going to upgrade the HP andTORQUE on your scoot ,you know your gonna use it.
I figuire since the bikes down anyhow you might as well do it now instead of later. Trust me it sucks to do all that work only to find out your clutch can't put it to the ground.[:@]
ORIGINAL: MAX EVO
Teu
My stock clutch seems to be doing fine.
Let's say this about that,you will be the first to know that your clutch spring need changing,the first time you roll the throttle on in high gear and the motor rev's faster than you are accelerating.Your clutch will not last long if you leave it like that.Good Luck
