Another stupid question that the manual does not cover.
I am about to change oil for the first time in my softail. The manual states to remove the drain plug from the oil tank but does not say anything about the small drain plug in the bottom of the engine case. It seems to me that the oil tank is located pretty high above the bottom of the engine case and there would be quite a bit of oil left in the engine case. Am I supposed to pull the engine case plug too? I think I will do this as well but am wondering if anyone else has noticed this or does this. Once again, my manual lets me down.
On the touring models(yours may be the same)that plug is only removed to check for sumping.
I would not mess with it until you know for sure.
You only need to drain the oil tank. The oil pump pumps the oil out of the engine and back to the oil tank. The plug in the bottom of the case is not to be removed. There will be a few ounces of oil in the engine, but that is ok. That is why your manual says to only drain the oil tank.
Don't pull the other plug on the case. Many people have had leaks afterwards and some have even cracked the case trying to get it back in. Do a search and read about some of the issues.
I have to ask do you have the "Service" manual or the "Owners" manual? My guess is you do not have a service manual. Get one, it will come in handy.
I feel like an idiot having to ask what may seem like real basic questions, but I have not worked on Harleys before and they are not like working on other bikes which I have lots of experience with. But this is how you learn....by doing!
Hahaha ya I saw your thread on the rear tire, suck that your S manual is letting you down, I guess I have been lucky with mine so far. Don't worry about asking questions that's what makes this website such a great resource, there is a wealth of knowledge and experience here, I will say that the Harley has been a transition for myself as well after years of wrenching on mertics, but once you get the jist they are really simple bikes to look after.
