Oval 3/4 helmets
Old 12-02-2013, 01:55 PM
Rhadgast's Avatar
Rhadgast
Rhadgast is offline
5th Gear
Default Oval 3/4 helmets
I've been researching 3/4 helmets for a few months now, in preparation for when I pick up my new Street Bob on January 3rd. Every helmet I've come across that has a basic 3/4 design (Bell 500, Biltwell, etc) seems to have a round shape. I've tried them on, and they always press on the back of my head, and forehead, while leaving big gaps in the temples and cheeks, which I assume will catch a ton of wind.
Is there ANY 3/4 helmet out there that will fit an oval head shape? What has been your experience? I just want something simple and comfortable.
Old 12-02-2013, 03:24 PM
Andjh123's Avatar
Andjh123
Andjh123 is offline
Interesting that the Biltwell didn't fit better for you. I have a similar shaped head that can give me excessive front-back pressure and was told somewhere that the Biltwell Classic actually fits this type of head. When I finally got a hold of one it fit almost perfectly and is nice and snug on the cheeks.
The catch here is that it's somewhat difficult to pull on and off, especially on the ears, because of how close together/sung the cheek part is and that there's very little give when trying to pull them apart to get it on or off your head.
I've gone as far as sanding slight depressions into the dense base layer foam in the front and back in one of my full face helmets. I'm sure this detracts from the protection that was "engineered" into the helmet even though I only took out a millimeter or so at most. It did make the helmet much more comfortable.
Old 12-02-2013, 04:35 PM
Rhadgast's Avatar
Rhadgast
Rhadgast is offline
5th Gear
Ah, yeah, I'd love to rock their non DOT helmet, but I'm looking for something with DOT approval.
Old 12-02-2013, 04:51 PM
09 YELLOWBIRD's Avatar
09 YELLOWBIRD
09 YELLOWBIRD is offline
I have all kinds of lids.
My 3/4 helmet is a Fulmer V2.
Good Price, Great fit and DOT too!
YB
Old 12-02-2013, 05:12 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
I have a very oval shaped head and I wear a Shoei Platinum RJ but I still need to stick a hat jack inside to slightly crush the padding on the forehead area to get the needed room.
Old 12-02-2013, 05:27 PM
one-up's Avatar
one-up
one-up is offline
I have an H-D "Trail" 3/4 helmet made by KBC - $140 at your H-D dealer. I'm an oval head and it fits me pretty good. Is there air leakage at the forehead? Yes a little, but not bad. I've ridden in 34 degree temperatures with it and have been quite comfortable along with a neck gaitor. I would have froze with a half helmet at that temp. Not trying to sell you a helmet, just saying that I like mine.
Old 12-02-2013, 08:54 PM
craigffb's Avatar
craigffb
craigffb is offline
I have two 3/4 helmets and they both fit a little different. The Fulmer V2 is tight around my face and a Rockhard American Classic that has a bit of a gap around my face.
The Rockhard is a much nicer helmet but the Fulmer fits better.
You might also want to check on the Daytona Crusier.
Old 12-03-2013, 04:53 PM
slapshot12's Avatar
slapshot12
slapshot12 is offline
I jet started wearing an RJ and have that same issue. I'm hoping the padding with squish a bit on the forehead. Gets a little uncomfortable towards the end of the day. I'm not an oval head though.
Old 12-03-2013, 05:41 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
Google, Hat Jack Hat Stretcher, they are $20. I find they do the trick on getting the needed room. Get the correct size as they come in 3 sizes. Much better than going through that pain.
ShockwaveTXB
08-08-2020 03:11 PM
ShockwaveTXB
04-23-2018 07:35 PM
Flyingtexan
07-22-2016 03:18 AM
j1mmy
09-19-2012 03:39 PM
Street Glider
03-07-2008 04:38 PM
Quick Reply: Oval 3/4 helmets
