Softail battery keeps going flat
Old 03-20-2014, 03:24 AM
Navs68's Avatar
Navs68
Navs68 is offline
Stage I
Default Softail battery keeps going flat
Hi all
I know there are threads with this already but not sure if anyone has seen this. I have had to change a 2 year old battery as one of the cells had given up the ghost. Put a new one in and had few flats since so it was time I undertook a methodical search with my multi meter and torch
Finally found the rear brake switch had cooked the neutral side of the switch off and the active was leaking via carbon left behind causing the battery to discharge slowly, flat battery would happen after 4 days of not riding which is rare as I ride every day.
New switch and all is good. Hope this helps
Old 03-20-2014, 08:15 AM
NDBadlands4-2's Avatar
NDBadlands4-2
NDBadlands4-2 is offline
Just fixed a similar problem in my kids car. I hate electrical problems.
Old 03-20-2014, 08:50 AM
MagDump's Avatar
MagDump
MagDump is offline
Banned Idiot Asshole
The only thing worse than a flat battery is a dead tire....
Old 03-20-2014, 12:29 PM
dickey's Avatar
dickey
dickey is offline
Received 5,493 Likes on 2,483 Posts
Instead of a torch, why didn't you just use a flashlight?
Old 03-20-2014, 01:29 PM
Uncle Paul's Avatar
Uncle Paul
Uncle Paul is offline
Softails tend to go through batteries pretty quick because they are mounted surrounded by the very hot oil tank. This slowly cooks the battery. Heat is the enemy of batteries.
Old 03-20-2014, 02:00 PM
Frostbite's Avatar
Frostbite
Frostbite is offline
Received 3,440 Likes on 1,557 Posts
Welcome to the forum!
You'll have to remember when you come here to translate English to American for us dumb locals...
Old 03-20-2014, 03:52 PM
heybaylor's Avatar
heybaylor
heybaylor is offline
my kind of thinking
Old 03-20-2014, 03:58 PM
txfxstrider's Avatar
txfxstrider
txfxstrider is offline
The last battery in my Softail lasted seven years.
Old 03-20-2014, 07:08 PM
harleydavis's Avatar
harleydavis
harleydavis is offline
My 1st battery lasted 7 years and I am at 6 years on my current battery.
Old 03-20-2014, 09:33 PM
harleyfiremedic's Avatar
harleyfiremedic
harleyfiremedic is offline
Had a similar situation in my sons 07 sporty. I searched high and low for he drain on his battery. Would die in about 48 hours. Finally had to take to a friend of a friend who works on bikes. Turns out there is a known issue that sometimes comes up with the 07's. Water got into the fuse box and corroded the connections in the fuses and the relays. Caused a short. Easy fix once he found it. I also hate electrical issues.
skinman13
09-06-2016 10:43 AM
hd4evr2008
03-11-2012 06:14 PM
stokes
01-02-2011 11:28 PM
tennessee streetglide
09-13-2009 07:37 AM
DLW_FLHTC
08-28-2008 05:37 AM
Quick Reply: Softail battery keeps going flat
