$150 lesson learned
Old Aug 27, 2008 | 10:09 PM
DLW_FLHTC's Avatar
DLW_FLHTC
Angry $150 lesson learned
I moved the bike in the garage two days ago and left the switch on and killed the battery. It will not take a charge so I had to replace it so I can get up to the 105th tomorrow. I hope I learned my lesson
Old Aug 27, 2008 | 10:25 PM
oldairboater's Avatar
oldairboater
How old was your battery? Brand?
Old Aug 27, 2008 | 10:27 PM
tda69's Avatar
tda69
You might consider purchasing a battery tender. http://www.batterytender.com
A great product and helps keep your battery in top condition. Of course it won't help you if you forget to turn it on.
Old Aug 27, 2008 | 11:01 PM
Toolguy's Avatar
Toolguy
It sounds like your battery was hooped anyway. You should be able to drain any battery and then recharge it. Leaving the switch on was not your problem. The battery was done. Better to fix it now in the garage than be on a ride and have it go somewhere inconvenient.
Old Aug 28, 2008 | 12:23 AM
baxter's Avatar
baxter
well its nice to always be able to pop the clutch if you have to , its alot easier to push start a bike by yourself then a car. ive done both. both still suck.
Old Aug 28, 2008 | 12:57 AM
Other Sheep's Avatar
Other Sheep
The garage is a great place to break down. Last battery that went on me I was about thirty miles from nowhere. Found out I couldn't get here from there.
Old Aug 28, 2008 | 05:37 AM
deadman77's Avatar
deadman77
Sounds like it was ready to go anway. Better that it crapped out at home than on the way.
See you at the 105th!!
I will be the one on the HD Fatboy!!
MikeM
bigpappa160
Electrical/Lighting/Alarm
Jan 9, 2016 08:17 AM
hd4evr2008
Mar 11, 2012 06:14 PM
eric95
Mar 16, 2011 02:14 PM
Softail Tony
Nov 12, 2009 03:12 PM
pdks
May 23, 2009 02:33 AM
