Had a brain fart
Old 05-09-2014, 01:08 PM
gatorlaw's Avatar
gatorlaw
gatorlaw is offline
Default Had a brain fart
Usually hand my lid on my low side passenger peg (2-1 exhaust with ghost pipe on low side). I parked in a less than desirable spot for a quick stop and hung helmet on the other side (where it was visible). Anyway I wasn't thinking and the helmet was resting on the hot exhaust and melted to the pipes. Not worried about the melt mark in the bottom of the lid but would like to get the melted remnants off the pipes if possible. Would rather not use steel wool as I don't want to scratch the chit out of them, of possible. Any suggestions?
Old 05-09-2014, 01:33 PM
mmancuso's Avatar
mmancuso
mmancuso is offline
Pick off what you can, soak the rest in Mothers or something similar, and try scraping off with some hard-edged plastic.
Old 05-09-2014, 01:45 PM
H3llb1lly88's Avatar
H3llb1lly88
H3llb1lly88 is offline
Start the bike And let it heat up. Scrape the gunk off with an aluminum or brass brush
pab3rd's Avatar
pab3rd
pab3rd is offline
run the bike and bake it off. But will smell and smoke
Old 05-09-2014, 02:03 PM
grumble's Avatar
grumble
grumble is offline
Easy Off oven cleaner. probably 1,000 threads on exactly how to do it.
Old 05-09-2014, 05:58 PM
bdtaylor1979's Avatar
bdtaylor1979
bdtaylor1979 is offline
I've used White Diamond Metal Polish
Old 05-09-2014, 06:27 PM
ChickinOnaChain's Avatar
ChickinOnaChain
ChickinOnaChain is offline
Big Kahuna HDF Member
Received 3,071 Likes on 2,555 Posts
Not anything as bad as that but boot marks on my pipes...I used a penny, laid flat and rubbed gently. The softness of the copper isn't supposed to leave a mark, which it didn't.
I read this method here.
Old 05-09-2014, 06:35 PM
sjef's Avatar
sjef
sjef is offline
Heat gun works good also, as it heats mainly the stuff you're trying to remove not the pipe.
Old 05-09-2014, 07:04 PM
DGRF250's Avatar
DGRF250
DGRF250 is offline
0000 steel wool with Simple Green or dish washing liquid. As long as you don't use the wool dry it will not scratch. Melted my Frog Toggs rain suit on mine going to Daytona, used the wool with no scratches
candave650
12-02-2014 07:45 PM
doer
12-17-2010 11:39 PM
baldu
01-18-2010 10:34 AM
swampfox_csa
01-05-2010 01:59 PM
SIM
09-11-2007 08:42 PM
Quick Reply: Had a brain fart
