3M paint defender spray film
Old 06-24-2014, 12:56 PM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 29,335 Likes on 11,165 Posts
Default 3M paint defender spray film
Has anyone tried this? Seems easier to install than the 3M film, that I have but have not installed. Thinking about installing on the front of the rear fenders, that catch stones, and the side covers.
Anyone have experience with the spray on stuff?
http://www.autozone.com/autozone/lan...der-spray-film
Old 06-24-2014, 01:17 PM
dbc58's Avatar
dbc58
dbc58 is offline
Used it last summer on the front fender and tank. Followed directions even using the provided wax. I guess I sprayed it too thin. Worked well but it was a PITA to remove. I had to re-apply a thick coat to get it to peel without tearing. Even then, it didn't all come off. I had to "roll" the rest off by hand. No damage to the paint. If you decide to use it, put it on thick so you can remove it later.
Old 06-24-2014, 01:26 PM
mmancuso's Avatar
mmancuso
mmancuso is offline
Friend of mine used it like a bra on his cage engine hood. He had a hard time removing it when it starting showing dirt, and the response from customer support was that he'd put it on too thin.
The bottom line is that you have to put it on so thick that it's very visible, and the whole point was something that was initially not visible.
Old 06-24-2014, 03:42 PM
dbc58's Avatar
dbc58
dbc58 is offline
Pretty much. I put it on thin to try and minimize orange peel. I applied 3 light coats in quick succession. It was slightly thicker than stretch wrap. Thick enough to remove is going to be really visible.
Old 06-24-2014, 07:54 PM
TriGeezer's Avatar
TriGeezer
Wow! Great feedback everyone! Back to reconsidering the 3M film that I bought.
Old 06-24-2014, 08:02 PM
Cheeto's Avatar
Cheeto
Cheeto is offline
I used it a couple months ago under my removable pillion. Put it on extra thick to keep from marring up the paint underneath since I ride with a solo seat most of the time. The stuff worked like a charm and came off no problem with no damage at all to the paint. Even after a few hundred miles the seat didn't wear through. I plan on using it again later this month on our next trip.
Squiggs31429
Powdercoat & Paint
07-24-2011 11:10 PM
harlanrider
05-28-2011 05:43 PM
cstolp
01-22-2008 06:11 PM
Custom07RKC
02-23-2007 11:30 AM
Hoopman
11-10-2006 12:21 PM
Quick Reply: 3M paint defender spray film
