General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
I just purchased a 2012 dyna switchback. I am now getting a P1632 and VI NNERR error codes. Any ideas what to look at...I hear a lot about low battery voltage, has anyone nailed down the cause for these codes?
Check negative wire to battery is tight
I believe a bad battery (cracked plate internally) can cause P1632
If you have a battery charger/tender put it on over night and see if it points to the battery.
