Reoccurring code help needed.
Old Jul 24, 2018 | 06:17 PM
mdanehart's Avatar
mdanehart
Default Reoccurring code help needed.
I have replaced the Engine Temperature Sensor on my 2013 Trask Turbo with Thundermax ECM. For whatever reason it shows a code after 10 or 12 minutes of riding. I clear the code via PC and comes back on again shortly after.
I have checked the leads and all good. Any ideas from the experts?
Old Jul 24, 2018 | 06:31 PM
ORradtech's Avatar
ORradtech
It might help to know what code is recurring.
Old Jul 24, 2018 | 06:37 PM
mdanehart's Avatar
mdanehart
Sorry, I got a case of dumbass. 117 and 118. Low and high ets.
Old Jul 24, 2018 | 06:59 PM
mdanehart's Avatar
mdanehart
I just completed the latest firmware on Thundermax and it automatically reset all codes. I know that’s not the fix but I will road test on Wednesday. Not sure what cause this issue.
Old Jul 25, 2018 | 06:11 PM
mdanehart's Avatar
mdanehart
Road tested after firmware upgrade. Bike passed the same code again, 117/118 engine temperature sensor Hi/lo.
I removed the sensor and checked the voltages. 0.01 on side of the connection and 0.02 on the side of the lead..
is is possible I have a brand new faulty sensor? Or any help?
Old Jul 26, 2018 | 05:34 AM
grbrown's Avatar
grbrown
I'd have a word with Trask, or whoever installed your kit. I'm not sure that many of us have experience with them.
Old Jul 26, 2018 | 05:55 AM
PFWiz's Avatar
PFWiz
Sounds to me like intermittent shorts / opens.
Check the cables / connectors to the sensor. (Don't forget to check the pins in the connectors)
Try wiggling and pulling the cables / connectors to see if you can induce the code yourself.
The problem actually sounds very simple, it is finding it that is difficult.
Jhatten
Electrical/Lighting/Alarm
Oct 9, 2018 01:05 AM
FLLarry
May 23, 2018 02:17 PM
mailmangjs
May 5, 2018 09:29 AM
John Kurz
Mar 31, 2018 05:55 PM
SEFast
Screamin Eagle CVO Models
Jul 11, 2016 05:09 PM
