2012 Roadking shut off twice at stops including electric
Two times I’ve rolled to a stop sign and the bike shuts off entirely (electric included). I flip my power switch off then on again, it starts right back up. I’m guessing a ground wire? Power switch? Bike has 8500 miles never had a problem. No new work done on it. It is due for maintenance. Any ideas? Thank you
Question
Is there any chance that my stereo may be causing this? It was installed prior to me buying. It was cutting out entirely off and on for a while now. I thought that it may have a ground not setting well. Could a wire from it short out the entire electric system of the bike? Far fetched I know. Thank you
The 2012 RK still routes most the power through the ignition switch so you have a loose connection somewhere. If you had a short, you'd blow a fuse. I'd suspect that the ignition switch is going bad if all the terminals are tight. You can pop the dash off and look at the connections to the switch, if any part looks melted, replace the switch and repair/repalce/solder the connectors on the harness side.
Dan89FLSTC (05-15-2019)
