Acc. switch quit working
Old Sep 22, 2008 | 03:50 PM
THABULL's Avatar
THABULL
Default Acc. switch quit working
I have checked the fuse it is fine but there is no power from the wire harness to the on/off switch , I have no clue on what to check next , any suggestions??
Old Sep 22, 2008 | 04:32 PM
GT_RoadGlide's Avatar
GT_RoadGlide
Does the rear brake switch work?
NH1200C's Avatar
NH1200C
In the 08's, the only thing between the battery and the Acc. switch is the Ignition switch and the P&A fuse (NOT the Accessory fuse!). I don't know if the wiring is the same in the 07's but I would suspect it is the same.
Make sure your ignition switch is in run or ACC and you should see power on pin 1E of the fuse block, and if the P&A fuse is good you should see power on pin 1F of the fuse block.
Old Sep 22, 2008 | 04:46 PM
GT_RoadGlide
The 07 fuse is P&A (15A) terminals 2F and 2E -- F is fused side
Old Sep 22, 2008 | 05:40 PM
NH1200C's Avatar
NH1200C
Thanks for adding that GT, I was hoping that someone with the proper manual would chime in.
I like your avatar! Semper Fi -
Larry
USMC 73-80
Old Sep 22, 2008 | 06:54 PM
THABULL's Avatar
THABULL
You are right it was the P&A fuse and that fixed it I was checking the wrong one. You would think the one marked accessory would be for the accessory switch. Thanks for your help!
Tris S
General Topics/Tech Tips
May 15, 2019 11:06 AM
ktnmeo627
Mar 3, 2017 09:22 AM
caltech
Mar 24, 2013 11:04 AM
Mike07FLHTC
Oct 8, 2008 08:50 PM
THABULL
Sep 15, 2008 05:54 PM
