1999 Roadking efi won’t turn on
Morning I have a 99 RK went on a ride from 150 mile bike ran good turn off on red light turned back on fine ran good got home turned off tryed turn it on next morning it would just crank over I have spark fuel n new battery I tryed starting fluid on throttle body see if it turn on Notting I chk cps it works good coil n wire are good sparks are new any help only code shows is cal 03
Be careful with starting fluid. That stuff is pretty harsh and a little can be too much.
If you have spark at the right time, with starting fluid, it should have done something. Are you sure about the spark?
Does it sound right as it normally does when cranking? Not faster or make unusual noises when cranking?
Check the air cleaner for obstructions and also the exhaust. A bird nest in either will prevent a start.
I'd check the compression before removing the timing cover. As mentioned, you need air, fuel and a spark at the correct time for it to run. And even if the timing if off some, it should still backfire through the intake or exhaust.
Start with the simple things first to eliminate them and go from there.
Paul
Paul
Gunny357 (09-02-2021)
Rather difficult for me to follow since it looks like a long sentence.
Reads like you have a 1999 Road King.
Unknown miles, unknown ownership history.
Unknown changes from factory stock.
In 1999 Harley had a recall or service thing about the bank angle sensor bracket.
The broken bracket would allow tip over switch to trigger and shut motor off.
Mullenix53
04-20-2013 10:36 AM
mo249
06-19-2012 08:04 AM
