Sticking Throttle
Old Feb 17, 2022 | 02:04 PM
WillGar's Avatar
WillGar
6th Gear
Default Sticking Throttle
My 2016 CVO throttle is sticking as throttle is applied. Not enough to make it hold but I can feel it as I roll the throttle. Any thoughts, fixes?
Old Feb 17, 2022 | 04:16 PM
MyFavRk's Avatar
MyFavRk
Have the bars been changed out ? Might be the switch pack is pushed on to far , try loosening the two screws and pull the throttle out just a touch until it " snaps back " as it should .
If the bars were changed out , it also could be the powder coating on the bars , sand them down to bare metal where the grip goes , then do the above .
Old Feb 17, 2022 | 04:53 PM
WillGar's Avatar
WillGar
6th Gear
OEM bars but the dealership did move them forward as far as they could so it would give me more room and still not interfere with the fairing. I'll try your first suggestion. Thanks!
Old Feb 18, 2022 | 06:12 AM
MyFavRk's Avatar
MyFavRk
That makes sense , when they pushed the bars forward , they would have had to loosened the switch packs to readjust , they just pushed the throttle side in a tad to much .
Old Feb 19, 2022 | 11:25 AM
WillGar's Avatar
WillGar
6th Gear
Well, gave moving the throttle a litte out try and still having issues. It's like a plastic rubbing plastic feel where it's kinda jerky as I roll it. I've even tried a silicone and still didn't help.
Old Feb 20, 2022 | 06:00 AM
MyFavRk's Avatar
MyFavRk
How are you making out , was wondering if you tried removing the grip and twisting the pod on the twist grip sensor to see if the pod itself is sticking , might need a new tgs .
Old Feb 20, 2022 | 07:11 AM
WillGar's Avatar
WillGar
6th Gear
I think I do need a new tgs. Took the grip off and had the same result by twisting the tines at the end of the pod. Thanks for the input. Deciding what's next since warranty ran out.
pyuchem
Apr 10, 2021 08:50 AM
ije
Apr 14, 2014 07:47 AM
sstlcm08
Jan 23, 2011 12:20 PM
stephenabel
Dec 19, 2010 07:09 PM
veeman129
May 9, 2007 01:31 PM
