OMT wheel bearing removal and installation tool tip
I know there have been many posts on how to install and remove wheel bearings, but I am starting a new thread as there is an important tip everyone should know. First, yes, definitely use a tool dedicated to this pur
pose as opposed to large mallets, screwdrivers etc. The OMT tool pictured here is really great,... except for one thing. As hard as I wrenched, I couldn't get the bearing to go in more than a 1/4 inch or so, and I didn't know why it was'nt moving until I backed out the tool and I saw I had turned the nut down to the end of the threaded part of the bolt.The long installer bolt did not have enough threads on it to pull in my wheel bearing on the primary side, the first bearing installed. I had to place the main body puller, the round piece in the upper right corner of the case, on the opposite side from the bearing I was installing, to take up the space. After that, everything went in like a hot knife through butter. I have not seen any mention of this issue and I did lots of research prior to my purchase. Great tool from OMT. Anyone who works on their bikes should have this.
dynoking (10-13-2023)
Thanks, Jim
