Harbor Freight Motorcycle Lift
I added this to the purchase as well when I bought mine years ago. Slight leak at the pump now, but I know what I have to do to fix it...........
https://www.harborfreight.com/1800-l...ock-61670.html
vicsponjr (01-14-2024)
I use a MaxxHaul 80077 Standard Motorcycle Wheel Chock with Pivoting Cradle now. Designed to accommodate bike tires from 14" to 21" diameter and 3-1/8" to 9" wide. But noticed today that when in position, the tire pivot hits the bottom of the fender of my 17' RGS. Looks like I'll have to cut and smooth the pivot so that it doesn't touch the fender.
MotoJockey (12-07-2023)
The following 3 users liked this post by 60Gunner:
twoglides13 (01-14-2024)
HF tables are one of those debated topics. Using friends table. Mixed feeling. Not the easiest to do by yourself, also with extensions, it can be far from you. Working on front end you can't turn the wheel to get at things.
actually I think i would like a jack that just went higher. Not sure I am really in a rush to get one. But I am sure I will at some point for height,
mcsteve (01-22-2024)
