Adjust Clutch Cable
Old Dec 31, 2023 | 09:54 PM
mobkinq's Avatar
mobkinq
Default Adjust Clutch Cable
Hello all,
Got a used 2007 Harley Road King converted into Street Glide. Previous owner did a lot of work to this bike. Both brake and clutch cables are steel braided. I adjusted the throttle fine. I am now looking into help adjusting the clutch with steel braided cables. Clutch lever has zero play and it’s quite hard/heavy to pull in. Really gets a good forearm workout going on. I would like to soften it a bit to be more manageable, unless if this is just how it feels being steel braided? Any ideas or experiences?
Thanks
Old Dec 31, 2023 | 10:32 PM
chopper_man's Avatar
chopper_man
The steel braid is essentially a cover, still has the plastic sleeve in there, it does not add any additional friction. It would use the same adjustment procedure in your service manual.
Old Jan 1, 2024 | 09:43 AM
mobkinq's Avatar
mobkinq
Great thanks! I will look for the adjusting nut and try and get the levers cleaned and cables lubricated as soon as I can!
Old Jan 3, 2024 | 06:05 AM
guido4198's Avatar
guido4198
Lubing that clutch cable will almost always improve the situation. Whatever you choose to use…Don’t rush the procedure.
Old Jan 6, 2024 | 12:33 PM
Fullbore55's Avatar
Fullbore55
You could look into something like this
Tanker2
2014-2024 Touring Models
47
Jan 7, 2024 12:42 PM
Softy 103
Oct 30, 2023 09:14 AM
PKS98S
Sep 1, 2013 04:12 PM
mang0
Nov 3, 2012 10:26 AM
BrianDamage
Sep 16, 2007 09:01 AM
