Cable or hydraulic clutch
Old Oct 1, 2017 | 07:49 PM
Softy 103's Avatar
Softy 103
Default Cable or hydraulic clutch
I put a set of Yaffe 10" Monkey bars on my 2012 street glide last winter and the dealer put a longer clutch cable on at the time, my clutch pulls a lot harder now and was considering going with a hydraulic clutch. Looking for the Pros and Cons of doing this. Any suggestions?
Old Oct 1, 2017 | 09:43 PM
hattitude's Avatar
hattitude
Alright, here's my 2 cents....
First, if you just added a cable with a few more inches, there shouldn't be that great of a difference in lever pull... they screwed up or didn't do something correctly...
As far as switching your clutch, you couldn't give me a hydraulic clutch.... their engagement zones are not adjustable, there is another complete hydraulic system to maintain, and the cable clutches I've had on all my bikes have not given me one bit of a problem...
What did the dealer use for a cable? There are some very good cables out there that can reduce resistance and lever pull on their own; Barnett HE (high efficiency) cables, HD Diamondback and Magnum are all considered better than, and easier to pull than, Harley OEM cables....
Then there are other products that can further reduce the lever effort/pull that replace, change or add on to the clutch cable ramp under the clutch release cover.
Cables are simple, easy to maintain & repair, mostly trouble free, fully adjustable, and have many options to reduce effort/pull..... I just don't see the need for a hydraulic clutch....
Old Oct 1, 2017 | 10:24 PM
wscott's Avatar
wscott
AGREE!
Scott
Old Oct 1, 2017 | 10:46 PM
t. sawyer's Avatar
t. sawyer
I agree.
kroozeabout.
Old Oct 1, 2017 | 11:02 PM
Jshopes's Avatar
Jshopes
I did +7 magnum cables and my clutch is no harder to pull. As far as a hydro clutch, they can keep that crap
Old Oct 2, 2017 | 01:13 AM
svarnster's Avatar
svarnster
ditto on keeping the cable
Old Oct 2, 2017 | 01:58 AM
tekman's Avatar
tekman
Have you tried spraying some lube or silicone down the end of the cable? Had the same issue and sprayed some silicone down the lever side of the cable and was night a day difference in pull. You'll need to loosen the clutch cable and remove from lever, but it's easy to do.
Old Oct 2, 2017 | 03:18 AM
Sam2010's Avatar
Sam2010
After everything going through with this 2014 and the hydraulic clutch
stay with the cable
Old Oct 2, 2017 | 03:24 AM
critter85's Avatar
critter85
Cable all the way!
Old Oct 2, 2017 | 06:50 AM
Softy 103's Avatar
Softy 103
OK looks like I will explore my options with the cable. Thanks for the replies, I am going to look at my invoice and see what cable they used and go from there.
