Let's play - "GUESS THE CRANKING COMPRESSION" GAME!
Old Feb 4, 2026 | 08:17 PM
Tcrafty's Avatar
Tcrafty
Default Let's play - "GUESS THE CRANKING COMPRESSION" GAME!
I know, it's corny, but it's winter and even in Florida we're having withdrawal.
So, we got ONE day this week when they weren't sprayin' oranges and strawberries with water to try and insulate them from the cold. It was cold this morning, but it got up to the high-60s to low-70 this afternoon. I figured that would make a nice ride home today. But...
I have the bike on a tender, but when I hit the button, it cranked REAL SLOOOOOW. Like I said, it was cold -- I took the truck to work. When I got home, I went right to the shed and tried crankin' the ol' gurl over. It cranked just like normal (like I said, it was warmer) and fired right up.
You may remember that I recently had my indy do an upgrade to a FM 95 ci kit with Woods 222 cams. I'm still lovin' it, but it has always cranked harder. I've attributed that to the higher 9.75 compression. In speaking with the folks at FuelMoto, the 9.75:1 kit was recommended since I wouldn't need to send out my heads for comp releases. Even so, it has always struggled much more than it used to whenever I start it. I'm lovin' what that added compression is doing for my complexion, but i was just surprised how much more my starter is feelin' it too.
So, I was going to do a cranking compression test, but found out that I don't have the M12x1.25 adapter. One is on the way. But, I figured I'd toss the question out there and see if you would like to take a guess at how much squeeze is going on under those twin-cam covers.
Here's the info on the kit used on my 2004 TC88:
So, what say you? Got an idea what the final compression numbers will be? I should have the adapter in a day or so, and I'll update with what I find on the gauge. Happy guessing!
Old Feb 5, 2026 | 08:07 AM
Max Headflow's Avatar
Max Headflow
I'd say 190 psi.. If you didn't clean the carbon out of the heads, 200 psi.
Old Feb 5, 2026 | 09:17 AM
MarlinSpike's Avatar
MarlinSpike
Veteran: Coast Guard
175-180 psi. Throttle wide open, cold cranking.
Old Feb 5, 2026 | 09:21 AM
Old New Rider's Avatar
Old New Rider
We celebrating up here in north country cause the temp cracked 20 degrees for the 1st time in a month.
Old Feb 5, 2026 | 09:25 AM
Rains2much's Avatar
Rains2much
I’ll go with 175-180. I’m kinda surprised FM said you may need compression releases over 9.75:1… is that corrected or mechanical compression? I’ve never really understood everybody freakin out adding compression releases and big starters… I turned 5” stroked 13:1 motors over with stock prestolite starters and an AGM battery from Harley… never an issue. My 93 inch Shovel is almost 12:1 and it currently uses a stock 1994 softail starter and an AMG battery. The trick was mostly in timing and big clean cable connections.
My little 93 inch shovel consistently shows 230 cranking compression. 590 lift 210 seat, 264 duration
Old Feb 5, 2026 | 12:30 PM
djl's Avatar
djl
Agree with Rains2much on the CCP; maybe the OP needs a battery? Just because it's on a tender doesn't mean much.
Old Feb 5, 2026 | 01:36 PM
Max Headflow
Not only that but you may have a typhoid mary charger..
BTW Being a softail. it has a battery smaller than a bagger.. The smaller AGM likely drys out faster.
Old Feb 5, 2026 | 02:12 PM
Ed Ramberger's Avatar
Ed Ramberger
350: SP Tree Fiddy – Mr. Throwback Thursday
Old Feb 5, 2026 | 03:39 PM
Ed Ramberger
Everybody needs one of these...
Old Feb 5, 2026 | 07:02 PM
Tcrafty's Avatar
Tcrafty
Always a possibility. I did go out and it fired right up. But, definitely something I'll be looking at.
Originally Posted by Old New Rider
189.9999
LoL...
I figured someone would do that!
And, is that chick to your right flippin' us off?
