Whistling in gas tank
Old Jul 13, 2003 | 10:01 PM
HDdavid's Avatar
HDdavid
Stage I
Default Whistling in gas tank
I have a 2001 electro-gluide with fuel injection</P>
I have a whistling nose coming from fuel pump/gas tank (the best i can tell).</P>
what would cause this pump, filter???</P>
waiting to here</P>
thanks hddavid</P>
Old Jul 20, 2003 | 01:27 PM
Gearhead99's Avatar
Gearhead99
6th Gear
Only thing I know that is in the tank that will cause a "whistle" is the electric fuel pump.</P>
Try this.....Shut bike off, then turn ignition to "on". Listen for fuel pump building up pressure then it will shut off, when engine isn't started. When it shuts off and the whistle goes away, well sounds like the fuel pump. </P>
The filter, also in the tank, doesn't have anything, that I'm aware of, that will make noise.</P>
</P>
Hope this helps.</P>
Orca76
Jul 13, 2011 06:45 AM
jaxx1972
Jan 4, 2011 04:46 PM
poppa cooter
Apr 17, 2009 09:21 PM
Pooh AKA Bear
May 3, 2008 04:30 AM
hartick
Apr 22, 2007 10:37 PM
