Leaking Gas
Old Sep 3, 2010 | 11:52 PM
lowhog56's Avatar
lowhog56
Stage III
Default Leaking Gas
I have a 100ci rev-tech motor pulled choke out to hard now i have gas running out the over flow. What should i do ?
Old Sep 3, 2010 | 11:55 PM
lowhog56's Avatar
lowhog56
Stage III
anyone who can help sure would appreciate it thanks. lowhog
Old Sep 22, 2010 | 01:55 PM
95custmz's Avatar
95custmz
Make sure choke cable is sill secured to carb body.Your leak at overflow tube could indicate stuck float.Also,if you have a petcock that does not have a vacuum hose you need to manually turn off gas flow at petcock.
evofloyd
EVO
Jun 8, 2011 08:37 PM
dwheelie
Mar 20, 2011 08:44 PM
MARVINN003
Carburetor Related
Jun 17, 2010 01:20 PM
Kodster
May 14, 2008 02:09 PM
2ez
Exhaust System Topics
Oct 29, 2005 07:44 PM
