gas smell
Old Mar 19, 2011 | 05:27 PM
dwheelie's Avatar
dwheelie
Stage I
Default gas smell
hi all, I have a custom hardtail shovel with older 5 gallon fat bob tanks. while sitting in the garage the gas smell is unbelievable throughout the house. There are no leaks. what could this be? Could this be from the vented side cap? any ideas? thanks
Old Mar 19, 2011 | 08:52 PM
the blob's Avatar
the blob
id think its the caPS. are they screwd on tight? any coming out the overflow tube from the carb?
Old Mar 20, 2011 | 08:15 AM
handyhoward's Avatar
handyhoward
There are three places for gas to vent... the caps... the tank vent in the front of the tank... the petcock (you need to turn it off when parked this will keep the gas from flowing thru the carb overflow)
Old Mar 20, 2011 | 08:44 PM
Dorkman's Avatar
Dorkman
Don't be too sure there are no leaks. The original cap has a pretty good seal, unless something recently was changed. Gas is basically a gravity feed. Touch every fuel joint, line, bowl, carb, float bowl, everything, with your finger and a paper towel. Bet you find something. Ditto the petcock. A strong gas smell is usually a leak.
Memo7070
Jan 29, 2013 03:09 PM
Kodster
May 14, 2008 02:09 PM
hammr_hed
Jan 22, 2008 07:54 AM
devilduck1
Aug 17, 2007 10:54 PM
2ez
Exhaust System Topics
Oct 29, 2005 07:44 PM
