speakers
Old Feb 24, 2007 | 01:52 PM
cozybay's Avatar
cozybay
1st Gear
Default speakers
Wondering if any one has used amped 3" speakers from Drag specialities/
trying to put some sound on road king without High $. any sug. would be great.
Thanks.
Old Mar 8, 2007 | 04:44 PM
ChicagoJ's Avatar
ChicagoJ
Default RE: speakers
I just went through this last weekend seeking help for adding tunes to my 01 Heritage. Check out a company on E-Bay called Two Wheeled Tunes. They have a set up specific for a Road King think it runs about $400 for everything. I'd give you the link but last time I did that it stretched the web page out about a block and a half. You can also look under the Softail section on page two. That's where my psot was with some of the links. Hope this helps.
Old Mar 14, 2007 | 06:37 AM
IndyRider's Avatar
IndyRider
I have a set from Uniq Cycle Sounds http://www.uniqcycle.com/proddetail....pkrs&cat=1that include a small amp, speakers, mounts and wiring. I ended up putting the amp in the left bag and wired it to the aux switch connection so I can turn it on and off with the switch.
I have found that above 50-55 MPH you need to crank up the volume pretty good to hear them. I use a Garmin Zumo GPS which has MP3 and XM as the input.
Best part they only cost about $280.
ReDo
Audio Systems
13
Aug 11, 2020 08:44 PM
bill_1202
2014-2024 Touring Models
Jul 29, 2015 12:25 PM
Christos0320@aol.com
Oct 1, 2013 08:18 PM
meyring81
Electrical/Lighting/Alarm
Apr 6, 2011 09:25 AM
phat96
Mar 15, 2010 06:25 AM
