1993 FLHTC Tour Pak mount and seat issues
I have a 93 FLHTC with a stock tour pak mount bracket. After completely rebuilding the bike from front to back, I ditched the quick release mount because the new rear fender fillers have caddy lights with no opening for the "boomerang" brackets to go through. NOW, when I take my "lowrise" seat off, and put the thick passenger Mustang seat on (it was on all last summer with the same fender and same bolt hole), I cannot slide the tour pak mounting bracket all the way forward to get the mounting holes to line up on the fender struts. It is hitting the back of the seat. So then I noticed that there may be a mounting hole on top of the pak mount to bolt the seat to. But that would raise the seat up too high with no support under the passengers rear and thus may make the seat break due to the passenger weight, bumps, etc. The rear fender is stock, with a filler kit molded on, so it is the same mounting point. it is the same seat I had last year. I realize it may be the seat, but I am wondering if I am missing something else.
Rockrivr1
08-28-2014 05:05 PM
