securing two Electra Glides in a trailer
I've seen quite a few videos where there in ample room in a trailer. In those videos, the bike straps are pulled straight out on each side of the bike. How do you secure a bike when there isn't room to have the strap come straight out? For example, if you have two full dressers in a 7x 14 foot trailer you might have a foot before you hit the wall. Pictures are always helpful. Also, who makes a ratchet strap that has very short strap material on the ratchet section?
Thanks
Thanks
Biker Bar
Best thing I've found is B & W's Biker Bar. http://www.turnoverball.com/products...er-bar-product I've got three I use in my trailer to haul two touring bikes and a trike. I used to use a Condor chock and tie downs but the Biker Bar is much easier to use and as secure as can be.
I have had the lock and load, and now have the biker bar. The biker bar is the best way to go. With the lock and load, you have to slide a long pin through to holes. It takes two people and you have to bolt a bracket on the frame every time. With the biker bar it works like a clamp around the frame and you ride on and it clamps tight. I have used this system for years with no problem. I have hauled my 08 FLHT from Va to Strugis, Myrtle Beach, Daytona & Clearwater to many times to count with no problem. Takes about 5 min to load and unload.
stroker87
02-06-2018 04:31 PM
JimGnitecki
General Topics/Tech Tips
03-27-2015 04:37 PM
