have to trike my bike
I have to trike my 09 Ultra Classic due to a minor stroke. My dealer is going with a Motortrike kit. Can I put a Champion reverse on this kit. and where would i get it. I have read some good things about this unit. Also do I really neee to rake the front and use the ez steer option. Thought about just getting the trike kit with reverse and a trailer hitch. Any of you other trikers got any other suggestions as to what i may need, (not want), but need.
Thanks
Thanks
I am sure the reverse kit will work with any conversion kit as it bolts on the transmission. You can google-up Champion for the contact information and they are good folks to deal with. I would just go ahead and rake it right off the bat. If you have lost any strength in your arms or upper body....you will do it later anyway.I know the EZ-Steer is a good piece, but some of us have used the Tri Glide tripple trees. I can point you to an article on another thread if you want the information. Just PM me if you are curious and want to save several hundred $.
We have an 09 TriGlide which has the reverse motor, but I very seldom use it, and then only to check it out every now and then. After riding it for a few weeks, I found it very easy to avoid situations where I have to push it up a slope, just by scoping out every parking spot like I do on my bike. Actually, it is much easier on the trike than on a bike to find a parking spot that you can turn around and let the trike roll back into, leaving your front end pointed uphill. If I park on flat ground, I can push it very easily, to either get into or out of the parking spot, and I have a 29 inch inseam. So, if I were buying another trike, I don't believe I would order the reverse to begin with. If you have some riding experience, you can probably avoid the need for reverse altogether.
By the way, my wife usually rides the trike, and with a little coaching, she doesn't often use the reverse either, but she says she still likes having it, just in case.
Since you are going to be adding the reverse option as a separate work item anyway, just wait until you ride the trike a little before you spring for it.
Good luck.
I think you will use the reverse more than you think. One of the things I like about having reverse is being able to use any parking spot. I used to pick pull thru parking spots in the past when possible. My Classic was HEAVY and I have short legs. With the Tri Glide and reverse, no problem. Enjoy your trike!
My '08 Ultra is in the shop being Triked right now. I went with the Champion Kit with EZ Steer and Reverse. The Champion reverse is a mechanical reverse that is essentially a "bolt on" to your existing six speed. You will be the best judge of whether you need it considering the weakness in the leg, which I hope will be a temporary inconvenience for you. As was mentioned previously you can save some money on the EZ Steer by installing trees from, I believe, a Street Glide. I'm 65 and am in pretty good shape but don't know how long that will last so I opted for the reverse and steering options. I'm gettin' antsy waiting on mine and will probably have to ride it home in the friggin' snow!!
