Trailer disconnected from bike at 60 mph
1 Post
I appreciate all the feedback.
Running without chains was never an option, I do criss cross them, that's what kept it following straight in my opinion.
I never thought about making the chains so short that they would keep the tongue from touching the ground. I don't think with where the chains attach to the trailer & where they attach to my bike that I can cut them short enough...I'll check it out this weekend.
alkay191;
your right, I was in the the trucking business from when I was 15 to 35 yrs old & I think I fired a guy for that once...
alkay191;
800...I cannot cut my chains short enough to guarantee they will never drag. If I do that.....it shortens the turn radius to much or gets caught on the ball mounting bolt when you do make a sharp turn. You need enough slack to enable maneuvering the trailer and I have mine cut at the very edge. It's about impossible to do that if your receiver hitch is hidden back up under the bumper and out of sight when you don't need it. Some of these service stations and motels have wicked steep and rough entrances.
I generally expect mine to hit the pavement on occasion and just change them out after a trip. I also use stainless steel chain. I use the heavy-duty (200 pound) snap-links on the chain ends as opposed to s-hooks. All I have to do is replace a couple of feet of chain had from Lowe's, Home Depot...etc. The snap-hooks will also prevent the chains from being jarred out of the safety loops.
Wizard, before you ask....NO...I do not mean those snap-hooks weigh 200-pounds. My wife can't lift that much.
I've never pulled a trailer with a bike, so please forgive the ignorance...
but, has anyone tried using cable instead of chain? I'd think it would be easier to tuck up out of the way and avoid dragging and sparking? also, plastic covered safety cable could be longer and run on top of the ball/receiver and not cause damage?
The trailer tounge for her trike came with ball attached. I think I'll put a hitch pin through the bolt now. On my Class three truck tongue for the enclosed trailer, the shop that I bought the trailer from used 150 lbs of torgue and red loctite on the ball set up they made up for me.
Best of luck in the future, ride safe, often and in good company.
