XiED Real World Test - Finally!
The benefits are ALL based upon the theory that the engine runs richer due to the tweaking that the Xieds do. you should at a minimum see slightly higher fuel consumption, although i would love to see the math the shows how many extra litres of fuel you use with a lower AFR than with the 14.7 - that would be interesting reading!
If one could get good repeat testing. Seems like logging the time the injectors were open w/ and w/ out XiED's along with flow of injector could get you actual amount of more fuel that was increased. Then one could decide if that was enough fuel to do anything with heat management.
It would also be interesting to test higher RPM and KPA areas for AFR. The stock Delphi does no learning above 3750 and 76kpa. It just takes what it learns below this area and applies it to the area above with adaptive. Since it is tricking the ECM into a lean condition to richen things up. This could be applied to the rest of the calibration.
Miketimer, what cable are you using to adapt the ELM adapter?
(RPMitUp requires a compatible WIFI OBD / OBDII Wireless scanner along with a 16 to 4 pin ELM327 cable.)
Here is a video: RPMitUp iOS and Android Tutorial - YouTube
I bought one off their facebook page: https://www.facebook.com/pages/RPMitUp/1414701695442958
Direct Link: https://www.paypal.com/cgi-bin/websc...=6HT8ZK8MDPJ3U
XiED: http://myappdata.com/#rpmitup/post/5...b05ccea51a6489
No XiED: http://myappdata.com/#rpmitup/post/5...b05ccea51a648c
IMO, you get what you pay for when it comes to tuning, devices, results and run quality.
When you buy a proper flash tuner and get it dynoed for best performance, response, smoothness, and fuel mileage there is no comparison to the results from add-on gizmos and/or screwdriver or push button tuning devices.
Once you've ridden a properly tuned/recalibrated bike, stock, or highly modded hot rod, you will be a believer and tell your buddies not to mess with the "toys" and get it done right the first time.
As always, JMHO,
Bob
As always, JMHO,
Bob
Showing up late to this party but I am interested in the XIED technology. The tester (MikeTimer) has a stage one already done to the bike. I wonder what the difference would be in temps if the XIED was put on a stock bike and then compare numbers? I bet there would be a bigger difference.
