13 SG Crank and no start...help
Old 08-28-2015, 12:10 AM
huddy's Avatar
huddy
huddy is offline
Default 13 SG Crank and no start...help
I just got done with a 3k ride and she ran great. Got home pulled both front and rear tires. Had them mounted and balanced put them back on and no start. She cranks and no fire. I can hear the fuel pump prime. I disconnected the fuel tank check valve and reconnected, no go. I disconnected the power chip, no go.
Only 20k miles on the bike.
Tomorrow I am getting spark plugs to check the spark.
Is there a way to check the check valve to make sure fuel is going through?
What could it be??
Fuel filter?
Ignition coil?
I will take any help as I have another ride on Sunday!!
Thanx
Old 08-28-2015, 01:35 AM
Next In Line's Avatar
Next In Line
Next In Line is offline
If there isn't enough compression detected, it will not spark. I just found this out while researching S&S EZ Start Cams.
Is there a clutch / kickstand safety switch?
Old 08-28-2015, 06:31 AM
chief08's Avatar
chief08
chief08 is offline
ckp sensor. take plug out lay it on head see if it sparks. if your getting fuel u should see it spray out plug hole. if u get spark and fuel it's crank position sensor
Old 08-28-2015, 11:49 AM
huddy's Avatar
huddy
huddy is offline
On my way to buy new plugs, leaving the old ones in to check spark.
No clutch/kick switch. I don't think I would get a crank if it had one.
Thank you!!
Old 08-28-2015, 04:45 PM
huddy's Avatar
huddy
huddy is offline
New sensor, no fire.
Fuel check valve is holding pressure and allowing fuel to pass
Still no spark too...What's next?
Spark cables? I'll test those...
Old 08-28-2015, 06:02 PM
huddy's Avatar
huddy
huddy is offline
could this be the coil?
how do i check the coil
Old 08-29-2015, 06:10 AM
chief08's Avatar
chief08
chief08 is offline
how do know it's holding pressure u have fuel pressure gage? check coil with omens meter check resistance. mite get a shop manual it will tell how to check coil. try systems relay. it sends power to fuel pump coil injectors. see if u r getting power to coil.? I hade a car do same thing it was ckp. hope u fix it be for sunday
Old 08-29-2015, 11:23 AM
huddy's Avatar
huddy
huddy is offline
I don't have a fuel pressure gage, but I depressed both sides of the check valve and fuel shoots across the room. Then I can repressurize and do it again. I also pulled the plugs after trying to start her and the plugs were wet. So I don't know what the pressure is but I have some.
bought a new systems relay, no go
So this is where I was at yesterday before I got you message. Doing the typical fuel, spark, ignition... thinking. What was new to me was the CKP sensor (Thank you) I didn't know you wouldn't get spark if it were bad. So when I put the new sensor in and still no fire and no spark I was bumming pretty hard. This might mean coil or ECM.
I went with coil first as your suggesting, and its not in the easiest of places! But I went to unplug it an see if I have power to the coil. I hardly touched and the plug fell out!!!! Now I have visually looked at this plug multiple times and it looked like it was plugged in, but it was in a such a small spot I never thought to get my hands on it.
Could this have been it all along you ask!!?? YES!! Had to use a screwdriver to reach it and get it plugged back in, but she fired right up! If your asking how this could have happened... well the other day I was washing the bike and must have been when I was washing around the top of the transmission and nocked it off.
Lessons learned once again. $6 really, $60 CKP sensor and some time and frustration, but still cheaper than a diagnostic test at the dealership.
Thanks for the help!
Huddy
Old 08-29-2015, 03:57 PM
chief08's Avatar
chief08
chief08 is offline
ride on glade u found it guess u will make your ride Sunday
jmd897
06-08-2017 10:58 AM
MNroadglideguy
General Topics/Tech Tips
05-19-2017 05:45 PM
deke463
Engine Mechanical Topics
12-25-2016 03:05 PM
deke463
12-13-2016 06:36 PM
Plumbwader
EVO
73
10-05-2015 08:18 PM
Quick Reply: 13 SG Crank and no start...help
