1995 80cu.in. EVO, ECM compatibility
Old 09-21-2016, 07:13 AM
mpescatori's Avatar
mpescatori
mpescatori is offline
Default 1995 80cu.in. EVO, ECM compatibility
Hello all,
I had many weeks ago started a thread "stalls when hot" expaining my predicament with a carburetted 1995 EVO Dyna.
Fully stock engine, no mods whatsoever, not even the ubiquitous Stage 1.
I came to replacing the crank position sensor in the nosecone, the coil and even checking the fuel vapor vent in the fuel cap...
I thought I had solved the problem but I evidently didn't, much to my chagrin, because yesterday, in thick, slow traffic, she conked out again.
No power to the plugs - I tested them and no power.
So now I'm looking at replacing the ECU/ECM (ignition module)
My ignition module reads ... ..."32464 - 95 // REV 1340 - 9508"
I have sourced one that reads "32449 - 95a// REV 1340 - 9530"
Are they compatible ? Can I remove one and fit the other ?
Please help, the bike is a good runner provided the weather is cool and I don't sit in traffic too long...
Old 09-21-2016, 09:21 AM
larsfum's Avatar
larsfum
larsfum is offline
I don't think that the 32449-95a will work. That is off of a 1996 Dyna. There are aftermarket models that a lot of the gents on the EVO forum have replace the stock model with.
Old 09-21-2016, 12:18 PM
mpescatori's Avatar
mpescatori
Default 8-7 adapter ?
Thank you.
No more than an hour ago I found an "8pin => 7pin" adapter.
I was hoping that, being two 80cu.in. carburetted VOs, the ECM would work.
But then... why shouldn't it ?
Old 09-21-2016, 08:39 PM
WP50's Avatar
WP50
WP50 is offline
Received 1,718 Likes on 1,168 Posts
I see larsfum on the EVO forum a good bit and I'm there too.
I'm thinking there are some good folks there that could help ya out.
Most times they are a good helpful bunch.
https://www.hdforums.com/forum/evo-classic-models-84/
WP
Old 09-23-2016, 08:38 AM
larsfum's Avatar
larsfum
larsfum is offline
Originally Posted by mpescatori
Thank you.
You can try using the newer module with the adapter, but I would get the correct module, and be done with it.
WP50 gives good advice about stopping in at the EVO forum. Those guys will steer you right.
Old 09-26-2016, 04:19 AM
mpescatori's Avatar
mpescatori
OK, thank you.
I will re-post my question in the EVO Forum.
Old 11-19-2019, 03:53 PM
newzealand's Avatar
newzealand
newzealand is offline
Hi MPescatori.
How did you get on with your enquiry. FXD 1995 rider in same spot, I ride an international model & want a module
mpescatori
EVO
17
10-03-2016 01:06 PM
yiannio
06-23-2013 01:32 AM
DarkSideFive
EVO
06-01-2013 09:07 AM
shovelhead FXEF
EVO
15
08-20-2012 04:46 PM
mtnman3
02-06-2012 10:55 PM
Quick Reply: 1995 80cu.in. EVO, ECM compatibility
