No Pwr to the Fuel Pump
Old 09-16-2017, 09:36 AM
cstorey's Avatar
cstorey
cstorey is offline
Stage III
Default No Pwr to the Fuel Pump
Went to start the bike, no buzz from the fuel pump. Checked power to the connecter at the fuel tank plate, no power, checked fuel pump fuse, works as advertised. Cant check the efi fuse but I know the fuse block is hot.
Any help would be appreciated
Old 09-16-2017, 11:59 AM
nevil's Avatar
nevil
nevil is offline
I'll assume you have the run switch on.
Fuel pump relay?
Old 09-17-2017, 05:17 PM
cstorey's Avatar
cstorey
cstorey is offline
Stage III
Default No Pwr to the Fuel Pump UPDATE
Went to start the bike, no buzz from the fuel pump. Checked power to the connecter at the fuel tank top plate, no power, checked fuel pump fuse, works as advertised.
Replaced System relay, still no power
Old 09-18-2017, 10:43 AM
larsfum's Avatar
larsfum
larsfum is offline
Year and model of bike? # of miles? Do you have power to other systems? Lights? Possibly ignition switch?
Old 09-19-2017, 08:18 AM
cstorey's Avatar
cstorey
cstorey is offline
Stage III
The bike is a 2008 Deluxe 32K on the odometer
I have power to all systems.
The bike will crank but no power to the fuel pump.
All components inside the fuel tank have now been replaced and working (fuel pump was tested on a different circuit).
Thanks for any help.
Old 09-19-2017, 03:59 PM
larsfum's Avatar
larsfum
larsfum is offline
Check your ground to the fuel pump.
cstorey (09-20-2017)
Ramman0220
05-14-2019 06:47 AM
Roadkingrobert
05-09-2019 05:54 PM
monster715
02-21-2015 02:34 PM
xtremechopper
07-12-2009 09:28 PM
sicksuperglide
01-02-2009 09:17 AM
Quick Reply: No Pwr to the Fuel Pump
